I recently did a CAM swap/head/intake swap on my 72, 307 V8. I did everything to the T. New cam is mild, 0.44 lift, new lifters, 305 re-machined heads and valves. I measured the new pushrod lengths and set the valve lash appropriately.
When I cold start the car, sounds great but after it warms up, especially after driving it for a bit, when I come back down to idle I get an audible tick. If I let it sit for a little bit idling the sound seems to quiet down. I bought a stethoscope and poked around while idling. Passenger side no problem. Drivers side, the sound is most noticeable at the No. 7 cylinder with the scope on the exhaust manifold. If I move it up to the intake manifold it's less noticeable. The tick sound sharp like metal on metal and not dull as I would expect an exhaust leak might. Since it's more pronounced on the exhaust manifold, am I looking at valve slap on that valve as opposed to a lifter tick or other issue? How bad is it to drive it?
