My Solid cam is calling for .026 of lash. Is that to be set hot or cold? Also doesn't that sound kind of loose? I have 1.5 Roller rockers on Intake and 1.6 on Exhaust, Was thinking about switching them around. Should I have to worry about any clearance issues with Valves? The heads are angle milled .125 and the deck has been cut and I have .125 pop up pistons. Things are pretty tight in there. I just want to make sure the larger 2.02 valve isn't going to introduce its self to the piston if I swap the rockers around
Cam is a solid lifter:
Operating Range: 4000-7500 RPM
Duration Advertised: 290° Intake / 298° Exhaust
Duration @ .050'' Lift: 252° Intake / 260° Exhaust
Valve Lift w/1.5 Rockers: .536'' Intake / .554'' Exhaust
Lobe Separation Angle: 112°
