Those vacuum readings seem like they're pointing to a vacuum leak somewhere unless you have a ridiculously lopey cam or something. I'm running a 234/238 @ .050" 112 lsa cam and I get 16" in park and 10-11" in gear at 800 RPM.
What kind of cam are you running? Is this engine stock or did you modify it? If its stock you should be seeing over 20" or so I'd imagine.
Common areas for vacuum leaks that cause big drops like that are at the intake manifold or around the carb base gasket. You can spray carb cleaner around the area while running to see if idle RPM rises or not.
Let us know some specs on your motor. Those vacuum readings could be right for a highly modified engine with a cam with a lot of duration, but if its stock or close to stock I'd suspect a vacuum leak somewhere.
