I just got a JW ultra bell for my TH350. Anyone have any experience installing it? The instructions say to remove the pump but it seems like some guys get away without removing it. Shouldn't be too bad of a modification either way.
Tips/Tricks....?
Vendor
I did mine when the case was empty. It took a few hours.I used a die grinder and shavings went everywhere.I am sure it could be done just tape up everything so you do not get any debris in the trans.
I already got the old case cut off but still need to trim about 1" closer. Definitely makes a mess with the grinder.
just did mine today, i pulled my pump out. the shavings went everywhere. just make sure you tape it all up. took me about 2 hours or so to complete it. keep a vacum around you to suck up all the shavings before you remove the rags/tape
