I have a 67 hard top that I have just recently lost turn signals in. While trying to diagnose the problem I lost the brake lights. I have replaced the brake switch, the headlight switch and now have brake lights, but no turn signals. The 4-way flashers work. I have the studied the wiring harness and determined it was either the turn signal switch in the steering column or the signal flasher. I bought a new signal swith and plugged it in and it did not make a difference. I did not mount it because it did not appear to need to be grounded to work. I also do not want to replace it if it is not the problem. I then looked for the signal flasher and could not find it. Can any one tell me where if is or is supposed to be? The fuse block does not appear to have a place for it, but i could not find it on the harness. Is it somewhere under the hood? Any help would be greatly appreciated.
Thanks,
Matt
Thanks,
Matt
