1 - 3 of 3 Posts
I have a problem with my turn lights specifically the parking lights and their side markers. The parking lights will flash correctly if the headlight switch isn't on. As soon as they turn on the dash turn indicator, the light will turn on and not flash. brake lights will work fine, just not the turn signals. Has anyone ever experienced this issue? If so how did you fix it? I've tried new flashers LED specific flashers and heavy-duty flashers. My next thing will be to look at the headlight switch to make sure a contact isn't shorting when pulling the switch.
1963 Nova SS and 1965 Nova
You need a no load flasher or timed flasher. The thermal type do not work with LED lights. Just re- red the post and saw that you have another flasher. Might need to check the grounds?
1 - 3 of 3 Posts
