I'm trying to find T D C using a piston stop , When I turn the crankshaft bolt ccw it loosens so I can't get the second reading . I pulled the plugs to lower compression, but no help. Any ideas ? Thanks I really appreciate the help
if you have the flywheel installed you can turn it that way too :yes:I'm trying to find T D C using a piston stop , When I turn the crankshaft bolt ccw it loosens so I can't get the second reading . I pulled the plugs to lower compression, but no help. Any ideas ? Thanks I really appreciate the help
what are you having trouble with why are you trying to find tdc ???I'm trying to find T D C using a piston stop , When I turn the crankshaft bolt ccw it loosens so I can't get the second reading . I pulled the plugs to lower compression, but no help. Any ideas ? Thanks I really appreciate the help
