So, would anybody think of adding a "Baffle under their rad. core support " ? ? ?
Ok - - this is just " info " ; (because my car is just a 'straight six motor' ) . . . . . but, it did come equipped with 'Factory A/C system' and, because of the a/c - - - it also has the
Heavy Duty Cooling package .
This HD cooling : has a V8 radiator , a 7 blade - V8 - fan blade (# 3947772) , with a 'Thermal Fan Clutch' , no fan shroud , but, a 'shorter style a/c water pump' (six cyl a/c only w/p) .
Then, here is my info : This system - - factory car w/ A-C , H D (VO1) cooling . . . . . also, included a "Rubber Seal" across the top of the rad. support - - - to seal the hood / core support " Gap " : makes more (forced) on - coming air go through the rad. (instead of over the core support ) .
Then, this H D - ( ROP #) - VO1 - (option) . . . . also includes a "A/C Baffle" : mounted under the front bumper - - back to the 'front frame cross-member' - - (look at the Picture = A/C Baffle ).
# 1 - -
Helps from 'picking - up - hot - road - heat' . . . . like . . . . in stop-n-go traffic , or - sitting at a red-light . . . ? ? ?
I do have some pictures of the "rubber seal" on the core support ( but not on this computer). but . . .
look here : Heart Beat City . com . . . . . they show one for the Camaro's - - - same thing . . . . . and cheap enough . If u'r intersted . .
Heartbeat City stocks a full line of NOS Camaro Parts, Rare Camaro Parts, Old Camaro Parts, Reproduction Camaro Parts and hard to find Used Camaro parts for your first generation 1967, 1968, 1969 camaro.
www.heartbeatcitycamaro.com
alot of people know this = = some people do not . . . . just FYI - - - - jim
