As you can see from this pic, my new trunk lock rod is much longer than the original. Also, the original is bent. I mocked up the new rod and it seems ok but sticks through the lock mechanism a good amount at the interior....no biggie.
The old BENT rod just makes it to the back end the lock mechanism, so it could work. The bent part is taken up a bit at the lock itself so it basically sits a bit cocked.
I want to use as many original components as possible. Each of these could work. Does anyone know if these rods are supposed to be bent? thanks.
