1 - 3 of 3 Posts
Does anybody have pics of the 2 rods that connect to the trunk hinges to hold the trunk lid open? (With them on the hinges on the car)
I took mine apart and cannot remember how they go back in. :(
Here you go, you may need an extra set of hands to hold them in place while bolting them up. The right upper hinge has the spring rod with the rubber in the middle and you can see that when installed it turns up after it passes through the right upper hinge.
[/IMG]
The right spring rod with rubber is on top as it crosses over the other rod, at least on my car.
[/IMG]
You can see the left side also has the spring turned up after it passes through the left upper.
[/IMG]
I remember this being a major PIA when I did it. Good luck.
1 - 3 of 3 Posts
