Im sure this is the most basic transmission question you'll see on this board.
But I have a TH350 and I want to replace the linkage seal. I have the tool and know what to do with it. I know I need to remove the U shaped bracket that is bolted to the trans that shifts through the gears. Its done by this lever/bar thing with a cotter pin in it. I took the cotter pin out and tried to slide that bar out but its in there pretty tight. I guess its bolted to some pivot point on the frame then runs up and is controlled by the column shifter. Is there some trick to freeing that bar that runs through this U bracket found on the trans so i can get to the bolt that holds that bracket?
Image...
http://www.chevyasylum.com/tech/68nova_198w.jpg
Thank you!
Image...
Thank you!
