I was wondering if you guys could help me out. My th350 has a leak. I thought it was the dipstick tube checked it out and no fluid around the the tube. I did notice fluid around the kickdown cable tube. I took the bolt out that holds tube in placed. When I pulled the tube up, I noticed the o ring that fits on the tube, only half of the o ring was left. If this seal is gone will it leak transmission fluid. Are there anymore seals that I need to look for. Now to replace the o ring can you disconnect the kickdown cable without taking the pan off. I have disconnected at the carb. Any suggestions. Thanks for the information. Roger
