1 - 2 of 2 Posts
I have a 64 chevy ll v8 with a turbo 350 that just crapped out. I want to switch the car to a manual transmission. I picked up a saginaw 4 speed but am not sure about flywheel, starter,clutch linkage, an all the other stuff. What all do I need and can I get the parts off any old standard chevy.
The pedals, linkage and bellhousing will be peculiar to 62-67 Novas. With these you'll want to use a 153-tooth flywheel and matching clutch. Make sure you have a pilot bushing in your crank. If it isn't a Nova block, you'll need a clutch ball adapter bracket.
1 - 2 of 2 Posts
