I am changing the trans from a powerglide to a th350 in my 65 wagon. What do I need to use for a mount? Can I order a mount for the PG?
Do you mean on the cross member?Just trimmed off the front lip to clear the 350 pan. Works like a charm:yes:
MisunderstoodDo you mean on the cross member?
Yep, that's what he means. I think you also lose access to some pan bolts? There are aftermarket crossmembers made for this swap, but modding the stock crossmember is the low buck option.Do you mean on the cross member?
