My TH350(with transgo kit) shifts fine from light to 3/4 trhottle but when I "stand on it" it seems to take along time to shift out of 1st gear. If I back off of the gas it shifts fine. Any ideas?
Thanks!
When I had TH350's I always cut the cable, pulled the guts and put the piece of cable housing where the bolt went through with some silicone, and put it back in. That will also eliminate full throttle down shifts. Or you can try adjusting the cable.
You would want the least amount of pull on the cable from the carb. So loosen the nu or bolt or nut/bolt(can't seem to remember), slide the cable towards the rear of the car in small increments, until desired affect is acheived. There may be another way, but that's how I did it. Good luck!
