350/350 in a '72, transmission don't line up with crossover...is this common? only a 1/4 in. but just wanted to make sure. Thanks, JD
Do you mean the cross member or exhaust crossover? If you meant the cross member try loosening the crossmember to subframe bolts and adjusting it.
how is it not lined up...to the right, left, too long, too short?????
Hey guys,
I called a buddy of mine and found out the tranny's are off to the left or right quite a bit. I had a friend push while I started the bolt. Thanks for the responses though.... JD
