My 64 is far from stock so a bolt in factory style cross member will not work.
I need to fab up a crossmember that will bolt into the car. To keep it simple I am going to use flatbar mild steel so I can tuck it under the car and clear my exhaust.
I think 1/4" thick by 2" wide stock will work - will this be supportive enough for a tran corssmember to prevent vertical movement? Anyone see any issues with using 1/4" flat bar beside the weight?
Thanks!
Thanks!
