1 - 3 of 3 Posts
Hi,
Im converting my 72 from a Th-350 to an M-21. I have the clutch assembly from a 68. Any suggestions on making it easy? I can't figure out how the new pedals fit in place of the old brake pedal. Does anybody have any pictures or diagrams to make it easier. Also, do you need to cut a hole in the floorboard for the rod that attaches to the fork? Thanks,
-Mike
Same crossmember yes. Driveshaft yoke is different I believe, you will need one like a TH400 has. Cant help on the pedals because the swap I did was in a different car. As far as the rod goes, the car I did the swap on had the hole already, it had a plug in it. Not sure if the Nova's are the same way.
1 - 3 of 3 Posts
