1 - 2 of 2 Posts
Another question today.
So I am putting a 700-R4 in the car and was looking at torque converters. A couple friends recommended a 2250-2400 stall converter. Then someone mentioned that if I get a converter that has a higher stall (2400) than what my final drive RPM is (hopefully 2000 or less at 70mph), I will burn up the transmission. It seems I have read about a lot of guys who have a 2400 converter and use a 700 and get the lower rpm advantage.
any thoughts here? Any other information needed to make educated comments?
just in case, it is a 406, 700R4, 3.73 gears, 245/45/17. looking for about 2000 RPM in Overdrive at 70mph cruise.
cale
cale
NOT TRUE!!
First off......Your converter only "Slips" when it's under MAX load.....NOT so much when cruising.
Secondly, the 700r4 uses a "LOCK-UP" clutch in the converter that locks up when at light throttle in 3rd and in O.D. :yes:
I had a 4800 stall in my wife's car (with a 700r4) and NEVER had a heat related problem. Once the converter locked up, it was no longer a "Stall".:no::devil:
1 - 2 of 2 Posts
