Hmmm...where to start.Marcellus, I wonder how you have the capacity to come up with such a power plant yet have no idea what chassis will handle it, not to mention basic NHRA rules that ANY BODY can obtain, especially those with deep enough pockets to have an engine like yours at there disposal. You spec a 5 speed so you can have overdrive, yet you spec a 3.89 rear gear. You spec a four link, is this a true drag race type 4 link or one of those rodder 4 links (I think they call it parallel arm suspension). You can't fit a drag race 4 link in that car without removing so much floor that it would require you to add at least a roll bar anyway. You state the vehicle has stock frame rails with a 9" and four link. Not saying it can't be done, just never seen such.
When you race your motorcycle you can feel when something is loose or not true. You know right where the fault is. That is because the chassis is tight with no flex. Still wonder about a cage?
The 4-link is a Checkered 4-link with a minitubb. This has been done over and over without modifying the frame rails.There are no mods to frame rails with the TCI bolt in 4 -link either. That's why I am limited to a 275/60 as far as I can tell, the frame rails. I am surprised you have a hard time grasping this.
As far as the motor, I built it to have more power than I really "needed". I never said I plan to run 10's, I said I expect the car to run low 11's and the car will be mainly street driven. Bigger cubes means the same power as say a 500HP 383 but with a little milder cam, lower RPM power band and better streetability.All things I am looking for.
I don't understand your comment on the OD and 3.89 gears. That puts me at about 72MPH at 2200RPM with a 27" tire. Right were I want the car to cruise.
The question really was more about what is the best option for a cage (if necessary) that keeps as much of the look and functionality of the car as possible. This car is not a full time drag car. It will have full interior including a back seat.
I am not sure of the point of your post. I though the point of this place was to be a resource to ask questions and get help with answers. I built most of my car using ideas and information off this site.
I have the "capacity" to figure things out on my own but I also have the "capacity" to ask people who have already been down this road for advice and opinion prior to missing something. I have already spent plenty of time redoing things on my car because I didn't think of a possible problem that cropped up in the middle of the work.
This is my first time building anything of this magnitude. All things told I had it to do over I would have put a TCI front end on it rather than a mini subb kit. I would have built a procharged LSX motor rather than a 427. As it stands I am where I am and look forward to driving it. I just wanted some opinions before I went down the roll cage path.
:salute:
