ProFit TKX 5-Speed Kit for 1968-74 Gen 2 X-body (Nova, Ventura) - American Powertrain
ProFit TKX Installation Kit for 1968-74 Gen 2 X-body (Nova, Ventura)americanpowertrain.com
"NOTE: Kit does NOT require modifications to tunnel, console or chassis."
Silver Sport Transmissions and others have kits available.
I'm planning to use one in a 66 project.
The information Bryanw80 posted indicates tunnel modifications are required. I know my car would require "some" modifications as it is currently a column shifted 4L60e that I got from Keisler. Silver Sport took over Keisler when they went out of business. Bryan if you pull the trigger on it you need to post up your experience from order date to burning rubber. I know a lot of us are interested in how it comes out."NOTE: Kit does NOT require modifications to tunnel, console or chassis."
I will post when I end up doing it for sure. I do believe there are no tunnel modifications necessary as stated by Silver Sport. I think American Powertrain has a misprint.The information Bryanw80 posted indicates tunnel modifications are required. I know my car would require "some" modifications as it is currently a column shifted 4L60e that I got from Keisler. Silver Sport took over Keisler when they went out of business. Bryan if you pull the trigger on it you need to post up your experience from order date to burning rubber. I know a lot of us are interested in how it comes out.
I am pretty sure doerf was the one I seen patching in the 4 speed hump.hole for shifter needed for stock column shift car, add the 4 speed hump patch to match stock 4 speed appearance, but probably not needed
