Spent the day getting the transmission mocked up. I used an old 307 block and bellhousing for this step. The crossmember was modified 2 years ago when I started this project.
After installing the trans into the bellhousing it was raised up to the floor and marked on the under side. Then small holes were drilled from the bottom up and the marks were transfered to the top for cutting.
no turning back now
transmission installed again
sitting on the crossmember and shifter installed
no turning back now
