1 - 9 of 9 Posts
Ok, I installed drop spindles and a disc brake kit. The front tires rub when turning now. I am looking for suggestions for a solution. Narrower tire? A different rally with more offset? "Roll" and trim the wheel well? A combination of these? I would appreciate any input. Here are some pics. BTW, the back is going to be lowered and the back wheel wells will be getting a minor trim.
rubbing by DanK1, on Flickr
rub 2 by DanK1, on Flickr
rub by DanK1, on Flickr
side view by DanK1, on Flickr
front by DanK1, on Flickr
lowered by DanK1, on Flickr
Wrong bs talley wheel.....what, size wheels...tires and back space?
I am not positive on the backspace. I think it is a 3 1/2 bs 15 x 6. It has a P205/60R15 now.
This is what it looked like before the drop spindles. I had worn out springs though)
"Prime Time" by cinnamonsnow, on Flickr
With those drop spindles your gonna need wheels with 4.5bs.....I hade the same size tire on a 14x6 ralley wheel with 4 3/8 back space and they did not rub:no:
14 x 7 rally here with 4-3/4" backspace. There is a guy here in NJ that cut my wheels and added the backspace that I needed. No more rubbing.
Looks like I may have to order some new rallys. Gotta do what I gotta do to keep this stance. It looks good. :) I appreciate all the input.
Update
The wheels are 15x7 and have at least a 4 inch BS. So I tried some new tires. P19560R15s. They work. And they look better anyways. I will trim and roll the fenders just as an added insurance. Will post pics later.
Bolt heads
My old tires rubbed on the bolt heads that hold the inner fender to the outer. I was changing my wheels & tires anyway and the new ones work just fine.
Discussion Starter #9
1 - 9 of 9 Posts
