Ok so I verified that there is indeed some kinda problem. My engine does not idle properly at the specified timing according to the mark on the ballencer. I was told these old ballencer's were rivited together and couldn't slip. They only go on one way.. What is going on here? I will verify TDC with a chopstick or piece of copper wire or something I can fit in the #1 spark plug hole.
The mark is probably 20 degrees off of where it should be if I have it timed right by ear and vacuum.
I AM using "regular" gasoline if that makes that much of a difference.
The engine is a rebuilt 283 stock harmonic ballencer and cover.. It should line up.
-Tom
-Tom
