what do you torque timingchain bolts to on a pre 87 305?
1 I would not#1 can i reuse the cam lock plate? #2 do i have to use locktite on it? #3 whats the best way to install a timing chain?
Do you have a? Motors auto repair manual?the cam sprocket mark should be at 6 o'clock and the crank sprocket mark at 12 o'clock correct?
cam and carb?do the marks on the cam and carb sprockets have to be lined up?cam sprocket at 6 o'clock.crank sprocket at 12 o'clock?
have you stepped away from the tools yet?yeah i meant crank sorry.
