Ok I know there are a lot of threads on timing but my question is where should I set the timing I have a 67 with a 250 a hei and a 2 barrel from stovebolt. I have the timing set at 4 btdc and I have a horrible dead pedal if I go a little past idle it just doesn't go. I thought timing might be an issue but if you have any other suggestions put them out there I need all the help I can get
had the same problem with mine. wasnt a timing issue it was my carb was way out of adjustment. closed both screws all the way then open them two and a half turns started it up and presto worked. i dont have hei but what a difference it made at take off:yes:
Thanks I think mine is set at a turn and a half some old timer told me that was a good starting point but I always thought he was crazy any way ;)
Still having a problem I'm not used to these carb things I grew up with fuel injection plug in a chip and your done performance tuned!
