i believe you would be cutting the shaft and adapting it to the new column with a coupler similar to this
Find ididit 3001001001 ididit Steering Column Installation Kits and get Free Shipping on Orders Over $99 at Summit Racing! All ididit steering column installation kits are made from quality materials and include the necessary components for installing your steering columns. There are several...
www.summitracing.com
or some other adapter/coupler to connect the column to your stock modified/cut shaft... i believe ididit makes a different style coupler also... you may have to contact them to check options... I have a MII style from setup, so i dont have first hand experience with a column and the factory box... but i did look into a while ago, prior to deciding to just upgrade the entire setup...
