so i installed a new 350 crate motor in my nova.it has vortec heads and intake.any ideas where to get the throttle and kickdown bracket that will bolt to the intake?it is a GM intake and holley carb.any help would be greatly appreciated.
Edelbrock sells a nice sturdy adjustable kickdown & throttle bracket that bolts to the back 2 intake bolts on the left side. it is a bit pricy at $32-35, but it's worth it. autozone & orileys carry it here.
i was looking at that one.so long as it bolts to the intake and gets me in the ballpark i could make it work.
Are you looking for this bracket? It is a factory bracket from a 76 Nova with a small block. To use this one the cables have to be of correct length to fit the carb. It would probably be better to go with an adjustable bracket or if using the stock bracket use cables that can be adjusted to the correct length.
I used an adjustable bracket and a stock cable because it was less expensive than trying to find a cable to work with the factory one.
