161 - 165 of 165 Posts
Replacement front brake rotors needed
I have the TCI Pro Touring suspension with the GM calipers and rotors.
What is the replacement part numbers or application for the brake rotors?
Mine are warped and I'm needing to replace them.
Thank you,
Glenn
I am getting ready to powder coat my front frame member... I wanted to mount the braided brake line mounting tabs first. Where is the recommended location for this part to be welded on? front or rear of A-arm? flat/perpendicular to the frame member? Anyone have pictures?
I put mine at the rear of the crossmember in the center of the tube.
Vendor
Discussion Starter #164
Thank you,
Glenn
They are 75-80 Granada rotors that have been redrilled for 4.75" bolt pattern.
We usually mount them vertically, just behind the crossmember on the frame rail.
-J
