Im pulling the transmission out of my car this weekend to put the other converter in, any advice or tips. Also, how much does a th350 weigh? I have a motorcycle jack that I think will go high enough to use, but if i cant, could a friend and I get it down with a floor jack?
thanks
-Dan
I think Ill make a list of what i have to do.
-Remove the drive-shaft
-Unbolt the converter from the flexplate
-Remove cooling lines, linkage to shifter, fill tube, speedo cable
-support the motor and unbolt the trans from the block
-remove crossmember and lower with jack
Anything I miss?
thanks
-Dan
Anything I miss?
