1 - 3 of 3 Posts
Overfilled? When my car sits for a month or more I get some torque converter drain back and it overfills the case a bit and oil will come out of the dipstick right after start-up.
It would be better to describe your tranny setup and the situation when the leak occurs so SNS members can bette help you.:yes:
yeh over full, do you have the right dip stick in it?.. it should blow out the excess then be fine.. that is if its coming from the vent on the top and not somewhere else! good luck
1 - 3 of 3 Posts
