Anyone got th400 in their nova and what cross member you running ? Im running a stock style one and can only get 2 bolts in. 1 on each side of subframe any one got suggestions for me
I'm running a small block and TH400.
I use the SBC/TH400 cross member from Tamraz's. I don't remember who the actual manufacturer is, nor can I find the small block specific cross member on their site now.
Lined up just fine.
Is it possible you have it backwards ?
I am assuming you have the correct TH400 cross member for a small block - since a big block TH400 cross member has the transmission mount offset to the passengers side.
I had a similar situation when I installed a 2004R transmission with an aftermarket cross member - only one hole on each side of the sub-frame lined up with the holes in the cross member.
I was able to notch a small section out of the sub-frame's cross member bolt access hole and drill an additional bolt hole that lined up with the bolt hole in the cross member. I did this procedure to both sides of the sub-frame.
Big block cars originally had the engine and transmission offset to the passenger (right) side - and I believe it's about 3/4". Aftermarket big block TH400 cross members do the same.
Do you think you may have a big block cross member, rather than the small block part?
Lined up just fine.
