1 - 13 of 13 Posts
Look under the hood you will see two holes in the cross piece. These are your starting point measure of those to locate the other 5 holes. Unless you have a 68 hood the cross piece has no holes and you will have to make a templete from another hood that is what I did for my 68.
Jason
velevick your in luck, I am restoring a 1970 Nova SS and I just removed the hood louvers so I can repaint the hood. I went out and made some very detail measurements of the exact location of the factory holes in my hood. I made a CAD drawing that I convereted into a PDF file, if you would like to see it send me an email and I will send it to you. I used a straight edge and drew a line across the hood through all four of the rear mounting holes and out the the edge of the hood, from there I measured how far the holes are from the rear corners of the hood. Then I measured from where the line intersected the edge of the hood and got the distance to the outter and inner holes. From the same line I measured all the other holes. There is a difference in hole spacing of he inner and outter holes, all of which I show on the drawing.
I know how hard it can be to locate stuff like this, I had to do the same for the side louvers and the NOVA tag because the previouse owner removed them and filled the holes.
Jeff
Banned
i'd be interested in this info if possible. i'd like ta add it to the Library.
can the pdf me posted or linked here ???
Thanks :D
side louvers & Nova tag location
I would be interested in the drawings / measurements for the side louvers & Nova tag also. Could you e-mail or post here as the hood louvers were?
1 - 13 of 13 Posts
