1 - 3 of 3 Posts
Trying to order up the parts so I can finally swap in my TCI clip. I tried mocking it up a little on the floor and I got about 18 inch for the steering shaft. I will be using the stock column w/ floor shift. And will be cutting the column shaft as close to the gearbox as possible. Does anyone know the length of their shaft? Stock column or not?
Sent from my ADR6350 using AutoGuide.Com Free App
Discussion Starter #2
Even and opproximate measuring will work. I have a line on a 22" DD shaft but waiting to be sure of other peoples setup.
Vendor
The CPP steering shaft kit I sell has 2 joints and a 3/4ddx18" shaft. If you have 20" or less between the column and the rack the 18" shaft will work.
Tim
1 - 3 of 3 Posts
