I installed a TCI clip on my '66 hardtop and like the quality of the components, 12" Willwood brakes and M2 power rack and pinion. After 18 months of disassembly, cuttting, welding, painting and drive train building, I now have it moving under it's own power. WOO HOO. But I am not happy with the cars stance. The front end is still too high compared to the rear which has new multileaf springs.
TCI tells me that the 300# springs will settle in 500 miles to where the A-arms are level to the ground. They mistakenly sent me 350# springs at first which were way wrong. The suspension was topped out with me sitting on the core support. The 300's are better but I still think the spring rate is too much. I have the battery in the trunk and have aluminum heads plus the lighter TCI clip which should pull about 100+ lbs off the front end I think.
I know I can drop the front end by cutting 1/2 or a full coil but that will just raise the spring rate which is too firm already compared to the rear leafs which feel good on bumps and dips. I'm considering the Heidts 275# springs as an option for a smoother ride and a lower ride. Has anyone tried 275# springs in a similar set up? Thanks for the help.
