do i NEED to buy a new ididit steering column for a tci front clip install? or will the stock one fit?
You can check with IBUILDM on this site and he can fix you up with parts necessary to use you existing column if you wish.do i NEED to buy a new ididit steering column for a tci front clip install? or will the stock one fit?
no youll need to cut your steering shaft loose from the old steering box ( down by the steering box ) and use the kit from www.cachassisworks.com it for there front clip but it works on the other ones ( tci , heidts , etc )do i NEED to buy a new ididit steering column for a tci front clip install? or will the stock one fit?
I have a two pieCe kit from Heidts that is made to fit your 67 column. The 67 column is the only year that disconnects from the box without a hacksaw. You need the SC-232 adapter and the shaft and u-joint kit SC-239 for a manual rack or the SC-249 for a power rack. They both sell together for $204. If you want a new Ididit tilt column and u-joint/shaft kit plan on spending about $520.You can check with IBUILDM on this site and he can fix you up with parts necessary to use you existing column if you wish.
