Of the two, I'd go 180 and make sure it's a high flow one.
Man, there's nothing like a good thermostat debate LOL. OK explain how a thermostat isn't a control device. For instance, let's say your cooling system is capable of cooling your motor down below 160° at all times without a thermostat. I know it would have to be a pretty good cooling system to start with. Well if the thermostat is regulating the minimum temperature to 160° or 180° isn't it controlling the temperature?what temp are you running now?
the T stat.. is a regulator for fast warm up... not necessarily a control item
and the key wasis a regulator for fast warm up... not necessarily a control item
I think you covered all the bases in your question... Ya left me no wiggle room... you correct in that if the cooling system can bring the temp below a desired operation temp then the thermostat then becomes a regulator, However, if like most factory systems they are designed to operate in a temp range and the Tstat mainly is a warm up helper... after that it stays open and then is dependent on the cooling of the radiator and fans...necessarily a control ITEM
Actually I did see your "not necessarily a control item" part; but not until after writing my epistle. By then I had already stuck my foot in my mouth so far I just left it all.
That's where this last edit originated from in my first post....... yep been there and done that.
Caught again red handed.ALLT4 said:There's a lot of different ways to say the same things about thermostats, I myself have got caught up in semantics not understanding how one side or the other is explaining things.
Your wrong. Read my reply to your other post in the other thread about this. If this were the case why when you put a pan of water on the stove and even though the burner is really hot, why doesnt the water heat instantly? The time the water is spent in the radiator is calculated and thats what determines the size of the tubes, width of the radiator and its capacity. It needs to be the correct size for the engine your cooling. If your radiator isnt efficient enough, you can only do so much, speeding the coolant up (high flow) will make it worse. The water picks up heat faster than it can cool it.The radiator doesn't need 'time' to do its job, it needs flow. The more water you flow through it, the better it works, same with the air side.
It's you're wrong....Your wrong. Read my reply to your other post in the other thread about this. If this were the case why when you put a pan of water on the stove and even though the burner is really hot, why doesnt the water heat instantly? The time the water is spent in the radiator is calculated and thats what determines the size of the tubes, width of the radiator and its capacity. It needs to be the correct size for the engine your cooling. If your radiator isnt efficient enough, you can only do so much, speeding the coolant up (high flow) will make it worse. The water picks up heat faster than it can cool it.
So if your cooling something more flow of water will help like the engine, but if your trynig to cool the water in the radiator, in order to do so you'd need air traveling across the radiator sufficiently cooler than the temp you want to bring it down to. But you dont have that unless its winter time. I forget but every degree outside air will have a bigger effect on how it cools.
Your head (EGT) are around aprox 1200* your throwing water thats 190* at it and trying to cool that water and keep it at the same temp with air that is 75* The time the water remains in the heat exchanger (radiator) is very crucial. You want it in there as long as you can.....to a point where the engine isnt going to have the temp rise. So you want to keep cool water coming. High flow T-stats are good for drag racing....where you throw a lot of water at the enigne, and cool it good, but once it heats up you need time for the car to cool down. Drag racing isnt continuos so you have time in between to cool. So you dont need a super efficient radiator. Lots of drag cars have tiny radiators, enough to get the job done and thats it.
What difference does it make what education or job title you have/had?USN, MM, or United States Navy, Machinist Mate, grad from A school, Great Lakes, Il. 5th in class of 50
AKA stationary engineering and 650psi super heated steam 2400hp steam powered single turbine.
750 degree super heated steam ( dry steam aka Invisible steam)...
latent heats, heat travel, thermal transfer, direction of heat flow, length of exchanger, type of heat exchangers, conductive, passive, etc.. inlet manifold temp, outlet manifold temp...type of condensate, salinity of condensate... plus 10,000 other things I have forgotten since then...
Mike an I have had similar discussions... he knows very well all the jargon I just threw down....
the system as a whole has to be taken into account, not just one aspect...
as a whole, a complete cooling system should be built to incorporate a 30% larger direct transfer (conductive) heat exchanger than required with passive elements incorporated(fins), a pump capable of transferring coolant 30% faster than required and a regulator capable of maintaining the desired temp...
then it all boils down to where you want the engine to live in a temperate zone.
I sure wish I could remember all the crap pounded in my head back then in 1972 by the USN.. but to many child hood experiments have gone by.![]()
In my 406 I don't run one.It runs cooler with out one.I don't know why but it does.So far this year I went 6 back to back runs spraying 150 shot it 90 degree heat and the car never got over 190.So I say try without one and with a thermastat and see what your motor likes best.
I believe that's why he used the wording he did. :yes:What would happen if you drove it 100 miles? Every application is different. Rich/lean conditions can also make or break you.
I drove it 80 miles one way and cruising at 75 [email protected] the temp was about 180.What would happen if you drove it 100 miles? Every application is different. Rich/lean conditions can also make or break you.
