1 - 3 of 3 Posts
Wiring a shift light and am thinking the best place to obtain switched power would be from the in dash ignition switch (65 Nova)?
If so, I believe I would access this wiring by removing the switch by removing the collor on the outside of the ignition switch. Is this correct? Do I need to remove the key cylinder as well? Do I need a special tool to remove the collar?
Why not just tap in at the fuse box, the should be tabs/blades for IGN, and ACC for a power source?
I used an ACC power source, but its not switched. I will see if any of the other free spots are switched.
1 - 3 of 3 Posts
