the ramps will work good your going to need jackstands at least 2 of them cause the stock bottle jacks arent really trust worthy your gonna need trans fluid ,pan gasket, filter might as well change the fluid in it while your at it your gonna need a way to keep the motor from sagging you sorta want to keep it where its at so you can line up the snout of the converter into the crank when your done you can leave the driveshaft in the trans just tie wire it back to the case and undo it from the pinion ( rear end ) if your going to leave it in the car gonna need to loosen the bellhousing bolts and remove the crossmember put a floor jack under the trans pan so you can move or lower the trans at least 3 to 5 inches also going to need to loosen up the converter to flywheel bolts too and then remove the converter carefully cause it will still have fluid in it as well oh and i forgot the first thing to do you can drain out the fluid all the way or about three quarts if you dont want to take the trans from the car
