OK....I switched from an 8.2 to an 8.5 with posi and 30 spline axles. My question is this......in putting everything back together, I see that my driveshaft u joints are not the same as the 8.5 rear end yoke. What is my best solution....change the pinion yoke to match the smaller ujoint or purchase a new driveshaft with the bigger u joint to match up with with the rear end? Thanks in advance for the feedback.
You can buy an adapter u-joint to go from the small driveshaft to the larger yoke. Most better auto parts stores have them.
Thanks Mike. I purchased it today and it went in perfectly. Thanks again.
