key off,signal switch in neutral position flasher is cycling when brakes are applied
.....do you have both flasher cans installed?
Key in accesory signal switch in left signal the flasher cycles and the starter engages when the flasher cycles
.....Are you serious?
Turn signals obviously do not work propery and when the brakes are applied only on front and one rear light come on brite Left side
....again, both flasher cans installed..if AAW harness is classic update, then the t/s column connector either has an adapter harness/connector or has new gm connector installed. You can check the wire routing to make sure it matches from t/s to new connector...
Frank
