Need some help here, I have a 71 Nova that needs some suspension work. The car is two inches higher on the driver side, front and back, from ground to center of wheel well. It is a Small block, it has traction bars, and I was told by the previous owner the front springs were replaced by some taller drag springs, the front tires have a major camber issue, the tires point toward the engine and rub the inner part of the tires bald. I think if I lower the springs that might fix the camber problem but why would the car sit two inches taller on driver side, front driver is 28" tall, passenger front is 26" tall, driver rear 27", pass. rear 25". How do I go about correctig this?
