been trying to tune my carb in and thought i had it all dialed in, but recently when im idling while in drive the car sorta lunges, not enough to move the car when my foots on the brake, but definatly something is wrong
almost at the point where im going to put a whole new carb on it(even went to the speed shop to price it out)
i
f i hold the brake and hold the gas pedal a bit it goes away, so maybe i can just up my idle speed a bit, but thats where i had problems w the carb before. idle speed was way too high and tranny would shift real hard into gear bc rpms were so high, after going through everything that time the only thing i could amount that problem to was some dirt stuck in the idle circuit of the carb
a little background info
194 six, holley 390 4 barrel carb, vacume advance
when i was messing w it last week,
-i put new plugs in (the burn on the plugs looked better than they ever have, but hey had a lot of miles on them)
-cleaned the dist cap and rotor (cap inside terminals always are covered in a white chalky residue that i scrape off, not sure whats causing this)
-set the timing, tuned the carb w a vacume gauge (got its highest at about 14 inches, may be higher think my gauge may be broken, needle starts a below the 0)
-HEI timing set at 8 degrees advanced, i know the advance is fucntioning bc if i unhook it, the car runs like poo on the freeway (higher up in rpms) but not sure what how many degrees the advance is
im pretty sure its running real rich, getting a strong smell of gas out the back
-also swaped out the carb to manifold gaskets and put in a new spacer(old one was cracked) this made it run a lot better got rid of probally a huge vaccume leak, it ran good for a few days and now its running as ive described above
help! going to mess w it sat morn, but not real sure where to start.....
(i know its a long post, hope i got it all in there)
i
