What are your thoughts on this motor, part #10067353. I need a few reveiws. It's the 350/260hp. 300ft.lb torque. long block. I'll put my factory two-barrel intake and carb back on, also the factory exhaust manifolds.
Not much HP, 260 @ the engine is like 150 @ the wheels with a 2 bbl. If your just wanting a fresh cheap engine its decent, but i think you should keep the original and freshen it up for half the price. if you get it id throw a 4 bbl kit on it and get the 260 out of it JMO.
It's a good low performance stock replacement motor. I had one in my 64 sedan and it ran good.
It's a quality "NEW" engine.
Still a 4 bolt.
this engine will come with a GM 3yr 100k warranty.
You might want to call around your area dealers and price this engine.
They can match or even beat this engine price. Saving you the freight cost.
Great decision!
AL
the engine dynos out at 260 hp with a 4 bbl and headers.so, with your 2 bbl and stock manifolds yours will not make 260 hp.i'd say it would be more like 200-210hp.but you should still have a good running gm crate engine with a warrenty for $1500.good luck.
Thanks for the reveiws. I was thinking that it would be 200 to 210 hp. I'll post updates soon.
