I have a 355 small block that is rated at 350 HP and 380 TQ. Would like to get it as close to the 400-450HP and 400-450 TQ range without changing the cam, if that would even be possible. I have the intake manifold off to fix a vacuum leak so I thought now would be a good time. Basically I am thinking I can only change out the heads and intake? Another problem is that I am not sure how to tell which cc heads I have, 76 cc or 67cc? Here are the specs on the engine:
Late Model 350 Block 1 piece rear seal
Bored .30 over & decked
Honed w/ torque plates
Cam .501/.512 lift, 224/230 duration, 111 deg lobe center
1.5 Aluminum roller rockers
World S/R Torquer heads w/ Manley 2.02 Intake / 1.60 Exhaust(Dont know if these are the 67cc or the 76cc head?)
Flat top Hypereutetic Pistons w/ moly rings
9-1 Compression(This is what was stated for the engine but I do not know for sure)
Edelbrock EPS Intake
650 Edelbrock AVS Carb
Fully balanced
All ARP bolts
Forged crank and rods also.
What would be a good option and a good cost effective way to get it as close to 450HP and 450TQ? I do not want to go with nitrous or a supercharger. Has a 2004R with 2500 Stall Converter, 3.55 rear now, but may be switching to 3.73. Thanksfor the help
Fully balanced
All ARP bolts
