I've been piecing together parts for a front disc swap. Going the LS 98-02 F body route. Keeping drums in the rear for now. I scored a master cylinder and booster from a 2006 Corvette that I plan on using.
My question is, since the master/booster I will be using is for the disc/disc setup of the vette, can I run a standard disc/drum combo valve like this one?
https://www.speedwaymotors.com/GM-Disc-Drum-Proportioning-Valve-for-1-2-20-9-16-18-Outlets,9878.html
And only have to include a 10 psi residual pressure valve for the rear drums like this?
https://www.speedwaymotors.com/Wilw...MI58_DnZen3wIVkonICh0UuQTmEAQYAiABEgJLB_D_BwE
I like that the metering valve is built in to the standard combo valve vs. having to purchase a separate one of those if I were to go the adjustable prop valve route (trying to avoid).
I'm looking to keep this as simple as possible, and would like to just get in and drive once everything is installed. The car is strictly a cruiser, so I was hoping to avoid an adjustable prop valve if possible.
Will this potential set-up work?
Thank you for any help/suggestions.
