1 - 12 of 12 Posts
.I am now looking toward some performance mods and wouldn't mind some suggestions if you have them. Here is a list of how the car will be set up.I am looking for around 400hp and a similar number in torque.
Engine: Goodwrench 350cid
Heads: Vortec 64cc
Trans: TH350
Stall: 2400
Gears: 3.73
Tires: 26"
Is like to have a broad powerband with something that is still useable and fun on the streets. Has anyone had any issues with summit and their cams? They are priced well which is appealing.
Heads: Vortec 64cc
Trans: TH350
Stall: 2400
Gears: 3.73
Tires: 26"
Is like to have a broad powerband with something that is still useable and fun on the streets. Has anyone had any issues with summit and their cams? They are priced well which is appealing. Thanks
The GM ZZ430 with the Hot Cam produces 430HP - 430TQ. Any cam around those spec's (Cam Lift: .525” Intake / .525” Cam Duration @ .050”: 218 deg. Intake / 228 deg. Exhaust
Lobe Separation: 112 Degree) with Vortec heads will get you to 400 / 410 on both HP and TQ. Use the Comp springes for your heads listed in this article (http://www.carcraft.com/techarticles/vortec_valve_spring_upgrade/index.html) to get the required lift out of your Vortecs...Jack
Cam
Hi,
I have a stock 400 short block with some EQ vortec heads on it and I installed the Lunati 60103 cam. It has too much lift if the heads are stock but I really like it. Good street cam.
Rick
What intake/carb you planning on using? I ran a Summit version of the Edelbrock RPM cam in my 350 and it was fuuuuun!
This was my combo-350 with FT pistons,Dart Iron Eagle 215 heads,Victor Jr intake,Holley 750 dp , 1 5/8 headers with 2 1/2" exhaust and a B&M Breakaway torque converter. Basically the same as you have. Like I said,it was a fun lil combo.
Heads: Vortec 64cc
Trans: TH350
Stall: 2400
Gears: 3.73
Tires: 26"
Compression ratio? Vortecs modified to accept higher lift?
I'm running almost the same setup as you, with the CompCam Xtreme Energy XE274H (274/286, 230/236 @ .050Lift .490/.490 Lift) in my 74 Omega!
355ci
Flat Top Pistons
Vortec Heads (modified to accept higher lift cam)
Edelbrock EPS Intake
Holley 650DP
MSD Streetfire distributor
TH350 w/3000 stall
3.73 - 8.5 Rear on a 235x60x15 drag radial ....
.... pulling 13.5's, 13.6's
The 268 and 274 XE cams are the most common cams for a Vortec top end. I've heard good things about Lunati too. The Vortec heads like split pattern cams.
The Edelbrock RPM Arigap intake works well with Vortec heads as well.
these would be my recommendations :yes::yes:
Clay Smith Hyd Rollers
Grind No. CSC-CHS-1-13-08HR
SBC 350 to 360 CID Vortec 185/205 GM Fast-Burn Head max power 6000-6200 rpm Peak Torque 3600-3800. Aggressive idle and throttle response. This cam is for the guy wanting neck snapping power from stop light to stop light. 1 5/8” headers along with 2400 stall will work the best with this cam. A “Dirty Bird” 750CFM carb would be the best choice. Use with minimum of 9 to 1 compression. 15" at 850 rpm
Part. No. Adv. .050” .100 .200 .300 Lobe Lift Centerlines Lobe Sep
150-3100 280/294 221/235 191/204 140/150 74/79 .340/.340 104/112 108
1 - 12 of 12 Posts
