I'm certain I forgot some things but below is a detailed description of the subframe and drivetrain. This is a complete bolt in assembly. Please feel free to reach out with questions or more pictures. Does not leak a drop of anything anywhere and is extremely clean with no grease or oil film anywhere. Excludes spindles and brakes.
Consists of:
ZZ4 with LT4 Hot Cam kit with 1.6 roller rockers
700r-4 with lock-up
2800 stall convertor
Freshly powder coated mini lower control arm kit, away bar
Coil overs
Demon carburetor
Power steering box (no slave cylinder setup)
Headers by Doug ceramic coated full length tri-y headers
Everything is powder coated
Total driveline including engine and transmission have less than 15k miles
Lower control arm kit
Sway bar
Power steering
Idler arm bearing kit
New parts within the last 1-2 months:
Borgeson PS Box
PS hoses
Coil over springs
All bushings
Inner and outer tie rods
Ball joints
Powder coating
All engine and transmission seals
HEI distributed
PS pump
Belt
Ceramic coating on Doug's full length tri-y headers
Transmission pan
Hoses
Thermostat
Plugs
Timing cover gasket
All new hardware
Borgeson manual drag link adapter
Consists of:
700r-4 with lock-up
Coil overs
Demon carburetor
Sway bar
Power steering
Borgeson PS Box
PS hoses
Coil over springs
All bushings
Ball joints
Powder coating
HEI distributed
PS pump
Belt
Transmission pan
Hoses
Thermostat
Plugs
Timing cover gasket
All new hardware
