1 - 3 of 3 Posts
Does anyone know if there is a templet available, for the mounting holes on a 69 subframe? I'm going to retore an extra frame that I have. But the rubber bushing holes are rusted, and I can't be sure where center of the large holes are? The alignment holes are great, So I can use them for a point of measurement? Thanks.
Here's a link to what your wanting http://www.classicindustries.com/co...ist=&productId=23534&productSearchCatalogId=2
I made my own when I fixed mine. The front body mounts were the only one's that needed fixed,(mounts at the firewall). I made a template and then welded them on the bottom side. You can get the measurements from the service manual, thats where I got mine. It give's you all the numbers that you need, center line of subframe and hole to hole center lines. Here's a picture of mine complete. Hope this helps, good luck.
1 - 3 of 3 Posts
