1 - 3 of 3 Posts
Hi everyone
I've read just about all the posts on here about installing subframe connectors but haven't found one that's helps.My questions are motor in , motor out does it matter,weight on wheels or support under frame with weight off suspension.
I'm installing the comp eng. bolt in but I'm going to weld also.
I would personaly want the drivetrain and all the suspension and body parts in place and the weight of the car sitting on the wheels. This way you can be sure the car is in its natural resting place when you tie everything together. Other wise it may twist or flex and you'll end up with doors that dont close right and panels that wont line up.
1 - 3 of 3 Posts
